bug in POP text export
  • Jan 16, 2023 10:11 AM UTC
  • 181 views
Hi all,
I have a question regarding the POP analysis. After calculating the POP in Zemax sequential mode, I save the POP result as a *.txt file where you have all informations. Aftwards I read the *.txt file via Python and do further analysis and plots.
In the header you see in line 9: Grid size (X by Y): 256 by 256
But when I read the data grid beginning in line 17, I get a grid of [255 x 256]
Is the data grid incomplete in height by one row?
greeting, Johann
Best answer by Jeff.Wilde
Hi Johann,
When I extract the POP data from the .txt file, I get a matrix with the proper size (e.g., 256 x 256).  Here’s what it looks like in Excel:
The total number of rows is 272 - 17 + 1 = 256 (i.e., rows 17 to 272, inclusive).
  • Jan 17, 2023 8:39 PM UTC
Hi Johann,
  • Jan 23, 2023 11:44 AM UTC
Ok I see, reading this table via pandas needs a lot of argumends such as names to set the column names.
