Hi Community,
Maybe I’m missing something simple, but is there an “Unhide Columns” in the MFE? In both the LDE and MFE, there is a “Hide Column” contextmenu option if you right click on a column header:
In the LDE, if I then right click on a column header, there is an option to “Unhide Column” but there is not an option in the MFE:
I can switch over to the Express View in the MFE to see all the columns, but without quitting OpticStudio to reset the column preferences, is there a way to show all the MFE columns in Normal View?
Thanks.
Best answer by Jeff.Wilde
