Bayer Filter
  • April 24, 2021
  • 78 views
Did anybody simulate Bayer Filter for color camera in sequential mode?
You can use a Slide surface to import a bitmap right in front of the image surface. However, it's not usual to do so. The purpose of a Bayer filter is to give separate R,G,B planes and you can do this in the software perfectly easily. Check for example the Image Simulation feature.
