Back Scatter - Scaling Issue
  • Apr 2, 2024 11:11 AM UTC
  • 93 views
David.M.Woods
I need to model both forward and back scattering from each surface in a lens system using ABg values.
For the sake of this example I set the ABg values to be the same.
The scatter forward/back is scaled to the specularly transmitted and reflected components. In this case, the surface Coating is set to I.99, so the back-scatter is 1% of the forward-scatter.
My problem:
I have been working under the assumption that AR coatings will not reduce the scatter - AR coatings can change the scatter profile, but the TIS tends to increase as coat layers only add to Rq*. However, simple coatings (6-layers or less) tend to the TIS of the uncoated substrate.
*Stray Light Analysis and Control, Eric C. Fest, Section 4.2
Therefore my scattering predictions are for uncoated substrates - giving me TIS values. I then scale them to the incident ray. So I ideally want the scatter of the surface to be independent of the AR coating.
Is there a way to tell Zemax to scale the scatter to the incident ray? Or do I need to upscale my ABg values to factor out the AR coatings?
