Automatic Solve Error: Clear Semi-Diameter
  • 1 June 2021
  • 210 views
Userlevel 3
Badge
Hello everyone,
I am using clear semi-diameter setting as Automatic Solve to fill the aperture up with rays. While I select the solve type as automatic I get an unphysical surface layout (on the right side). With the default seetings I have a view as on the left side.
My aim is to correct this unphysical lens layout by retaining the initial focus.
I suppose this oddness on the right can easily be solved by a commonly known trick. I am open to your suggestions,
Thanks in advance.
Önder.
icon
Best answer by Csilla Timar-Fulep 1 June 2021, 16:18
Userlevel 5
Badge +2
Hi Önder,
You can try to use the Edge Thickness Greater Than (ETGT) optimization operand to avoid this kind of unphysical lens layout:
You can set the radii of curvature and/or the lens thickness to variable, and optimize your system for e.g. RMS Spot size to achieve best focus with additonal ETGT operand to avoid the unphysical lens layout.
I hope this helps, but if you have any further questions, please ask!
Csilla
Userlevel 3
Badge
thank you so much for your help Csilla!
