Annulus/cylinder2 pipe absorbing property does not work
  • Jan 4, 2025 12:22 AM UTC
  • 105 views
Erkang Wang
Hi, I am trying to use an anulus and a cylinder 2 pipe to form a lens aperture stop, I set both to ABSORB at the material taps. But there are still a lot of rays pass through. I close the anulus or open the anulus, the intensity on the detector is the same. Looks like they are still transparent. Could you tell me how to fix this. Thanks so much
Erkang Wang
  • Jan 8, 2025 11:54 PM UTC
If I put the anulus before the paraxial lens, the anulus is transparent. If I put it after the paraxial lens, it is a absorber. Is it some default property of the paraxial lens?
