Adding absorptive material (kind of metal) to material catalog in NSC mode
  • Aug 22, 2024 2:00 AM UTC
  • 635 views
Gyuheon Lee
Dear all
I design an optical fiber (INF3: CORE refractive index = 1.489, CLADDING refractive index: 1.476 at wavelength 3.3 um) and displace a Cylinder Volume(the object #5) on slight air gap region(0.1 mm).
I also try to set material of this object as Au. However, I cannot find the way to add absorption coefficient(‘k’ of ‘n + ik’) of material. In material catalog, I could only add real part of refractive index vs wavelength. Is it possible to set absorptive material in Zemax? (I already know how to use coating in absolute thickness. But I wonder if the cylinder is coated in radial direction, inside or outside)
Any other recommendations for absorptive material simulation are welcome !
Thank you
Optical Fiber
NSC Component Editor (object #5 is Au Cylinder)
@Gyuheon Lee
In the Libraries..Materials Catalog, for every glass defined, you have a button Transmission.
In there, you can define transmission as a function of wavelength and reference thickness.
Please see the Help File section: The Libraries Tab » Optical Materials Group » Using Material Catalogs » Defining Transmission Data for more details. I hope this helps.
  • Aug 23, 2024 10:56 AM UTC
@Gyuheon Lee
