3D Layout gets stuck [Ansys Zemax 2024 R1.03]
  • May 29, 2024 3:06 AM UTC
  • 366 views
3D Layout gets stuck after a while and does not respond to mouse scrolls or clicks. Anyone else facing this issue in 2024 release ?
Best answer by Sean Turner
Yes, this is still an issue for me as well. I also notice the workaround I mentioned in your previous topic is very slow now. I have a non-sequential model that can take 7+ minutes to load the 3D layout when I switch to the Classic tab, but only 3 seconds to load when I switch back to the Graph tab.
Sean Turner
  • May 29, 2024 12:41 PM UTC
  • Jun 4, 2024 11:06 AM UTC
Just to add a data point, I have observed this on versions prior to 2024. At least on the 3D shaded view.
I filed a support ticket October 2023. #64230. Ticket’s been closed, a bug was filed.
Freezing started for me in Opticstudio 23.2.1, and continues to be a problem through to OpticStudio 2024R1.03 that I’m using now.
I clone the window and close the old one, but it’s extremely irritating. Next time will try the switch to classic view and back.
  • Jun 8, 2024 4:15 AM UTC
I’ve been having problems with both the standard 2D Layout and the 3D Layout windows essentially locking up.  Hopefully this can be fixed in the next release.
