I’m working on a project to understand higher order aberrations in the human eye. I have obtained some Zernike coefficients data of patients, the wavelength at which the measurement was performed at (840nm), and their pupil diameters.
As I don’t have the ROC of the lens in the eye, is it possible to model this in Zemax? I would like to use the “Extended Scene Analysis” to visualize what the patient sees, based on his/her Zernike coefficients.
I have read the article “How to model a black-box optical system using Zernike coefficients”, but don’t quite understand how to determine the exit pupil position.
Thanks in advance!
Hi Yao,
Thanks for your post here on the Community Forums.
The parameters for the patient’s eye are provided (lens radii, thicknesses, etc).
Which parameter of this patient eye is different from a normal eye?
Thank you.
Thanks in advance!
Page 1 / 1
Hi Yao,
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
