OpticStudio can not load DLLs
  • Jun 18, 2021 1:11 PM UTC
  • 533 views
I tried to use the original Gaussian.cpp in Visual Studio 2019 to create a dll project. I created a default dll project and copied the Gaussian.cpp and tried to build the file. The header file is left empty. The build was successful but when I tried to load into Zemax, it gives error saying cannot load DLL as in the attachment.
Hi Xiaohui,
I don't have a file Gaussian.cpp in my default installation of OpticStudio. Can you elaborate what DLL you are trying to build? Is that a source, or a surface? Can you also share the file you are trying to compile for troubleshooting?
  • Visible
  • May 23, 2023 1:18 PM UTC
Hi Xiaohui,
Hi David,
I currently face a similar issue with a Source DLL and I’d be happy to get help with it.
I’ve tried to modify AstigmaticGaussian.cpp to produce higher transverse modes.
Unfortunately I face the same error message as Xiaohui attached above.
See my code attached.
Looking forward your reply,
Oran
