ZPL Macros: What FUNCTIONS and KEYWORDS are replaced or obsolete?
  • March 16, 2020
  • 525 views
Katsumoto Ikeda
There are times when we run an old ZPL Macro and it may not work in the newest version of OpticStudio. This happens because FUNCTIONS and KEYWORDS are obsolete, even though Zemax/OpticStudio have not made any KEYWORDS obsolete since before 2006, and only 1 function obsolete in the past 5 years.
The table below is for mapping the FUNCTIONS/KEYWORDS. If you have a macro that doesn't work and are forced to use Zemax 13 or earlier, perhaps you can check the table below and lookup what the old code is to manually map it and make it work in the newest version of OpticStudio.
Feel free to add any we've missed in the comments section, and I'll update the main post.
Type
Old
New
Comment
Function
FVAN(x)
FTAN(x)
Function
STDD(surf, 0)
SPRO(surf, 60)
Function
STDD(surf, 1)
SPRO(surf, 61)
Function
STDD(surf, 2)
SPRO(surf, 62)
Function
STDD(surf, 3)
SPRO(surf, 63)
Function
STDD(surf, 4)
SPRO(surf, 64)
Function
STDD(surf, 5)
SPRO(surf, 65)
Function
STDD(surf, 6)
SPRO(surf, 66)
Function
STDD(surf, 7)
SPRO(surf, 70)
Function
STDD(surf, 8)
SPRO(surf, 71)
Function
STDD(surf, 9)
SPRO(surf, 72)
Function
STDD(surf, 10)
SPRO(surf, 73)
Function
STDD(surf, 11)
SPRO(surf, 74)
Function
STDD(surf, 12)
SPRO(surf, 75)
Keyword
APMN surf, value1
SURP surf, 21, value1
Keyword
APMX surf, value1
SURP surf, 22, value1
Keyword
APTP surf, value1
SURP surf, 20, value1
Keyword
APXD surf, value1
SURP surf, 23, value1
Keyword
APYD surf, value1
SURP surf, 24, value1
Keyword
COAT surf, value1
SURP surf, 8, value1
Marked as obsolete in Help Files
Keyword
COMMENT surf, value1
SURP surf, 1, value1
Keyword
CONI surf, value1
SURP surf, 5, value1
Keyword
CURV surf, value1
SURP surf, 2, value1
Keyword
EDVA surf, value1
SURP surf, 11, value1
Keyword
GLAS surf, value1
SURP surf, 4, value1
Keyword
PAR1 surf, value1
SURP surf, 10, value1, 1
Keyword
PAR2 surf, value1
SURP surf, 10, value1, 2
Keyword
PAR3 surf, value1
SURP surf, 10, value1, 3
Keyword
PAR4 surf, value1
SURP surf, 10, value1, 4
Keyword
PAR5 surf, value1
SURP surf, 10, value1, 5
Keyword
PAR6 surf, value1
SURP surf, 10, value1, 6
Keyword
PAR7 surf, value1
SURP surf, 10, value1, 7
Keyword
PAR81 surf, value1
SURP surf, 10, value1, 8
Keyword
RADI surf, value1
SURP surf, 2, 1 / value1
Keyword
SDIA surf, value1
SURP surf, 6, value1
Keyword
SETSTDD surf, 0, value1
SURP surf, 60, value1
Keyword
SETSTDD surf, 1, value1
SURP surf, 61, value1
Keyword
SETSTDD surf, 2, value1
SURP surf, 62, value1
Keyword
SETSTDD surf, 3, value1
SURP surf, 63, value1
Keyword
SETSTDD surf, 4, value1
SURP surf, 64, value1
Keyword
SETSTDD surf, 5, value1
SURP surf, 65, value1
Keyword
SETSTDD surf, 6, value1
SURP surf, 66, value1
Keyword
SETSTDD surf, 7, value1
SURP surf, 70, value1
Keyword
SETSTDD surf, 8, value1
SURP surf, 71, value1
Keyword
SETSTDD surf, 9, value1
SURP surf, 72, value1
Keyword
SETSTDD surf, 10, value1
SURP surf, 73, value1
Keyword
SETSTDD surf, 11, value1
SURP surf, 74, value1
Keyword
SETSTDD surf, 12, value1
SURP surf, 75, value1
Keyword
SURFTYPE surf, value1
SURP surf, 0, value # use 8 character code
Keyword
SURP surf, 17, value # use integer code
Keyword
THIC surf, value1
SURP surf, 3, value1
Keyword
ATYP value1
SYSP 10, value1
Keyword
AVAL value1
SYSP 11, value1
Keyword
FLDX value1, value2
SYSP 102, value1, value2
Keyword
FLDY value1, value2
SYSP 103, value1, value2
Keyword
FWGT value1, value2
SYSP 104, value1, value2
Keyword
FVDX value1, value2
SYSP 105, value1, value2
Keyword
FVDY value1, value2
SYSP 106, value1, value2
Keyword
FVCX value1, value2
SYSP 107, value1, value2
Keyword
FVCY value1, value2
SYSP 108, value1, value2
Keyword
FVAN value1, value2
SYSP 109, value1, value2
Keyword
FTYP value1, value2
SYSP 100, value1, value2
Keyword
GCRS value1
SYSP 21, value1
Keyword
NUMFIELD value1
SYSP 101, value1
Keyword
NUMWAVE value1
SYSP 201, value1
Keyword
SETAPODIZATION value1
SYSP 13, value1
Keyword
SETTITLE value1$
SYSP 16, value1$
Keyword
SETUNITS value1
SYSP 30, value1
Keyword
TELECENTRIC value1
SYSP 14, value1
Keyword
WAVL value1, value2
SYSP 202, value1, value2
Keyword
WWGT value1, value2
SYSP 203, value1, value2
Keyword
PWAV value1
SYSP 200, value1
Hey Kats, thanks for this. Am I correct that the obsolete stuff is still there, and macros that call them still work, or has that changed?
BTW, you can check your macro for obsolete syntax using the CheckObsoleteSyntax checkbox on the Run/Edit window
Katsumoto Ikeda
Hi Mark, my understanding is that the obsolete function do not work, and I have heard of some of our customers that still use Zemax 13 since they cannot pinpoint which functions are obsolete. I am hoping this can be a starting point for people to update macros that are essential in their design process.
Thank you for pointing out the CheckObsoleteSyntax, this is great additional information for the thread!
Hey Kats,
Yes, if anyone is using old syntax, it should be picked up by the syntax checker, like this, erm, example from the current distribution:
I am surprised that any obsolete keywords have been removed from the code without that removal being documented by someone. It always used to be policy that changes to .ZMX and .ZPL files always be backwards compatible, so when we added SETSYSTEMPROPERTY to replace the hundreds of separate RADI, THIC, PWAV etc, we kept all the old syntax specifically so as to not blow up existing macros. Surely it must be possible for the developers to say what, if any, macro commands have been specifically removed? Somebody must have done it...
