Using target values from Merit function in ZPL Macro
  • Jan 28, 2022 5:13 PM UTC
  • 794 views
Is it possilbe to use target values from a merit function in a zpl macro.
For example, there are some defined constraints in the optical path length (OPTH) for e.g. 5 different ray deflections (different Hx or Hy) of an imaging system. Can I use these fixed values in the ZPL macro for further optimization?
Hi Ralf,
I’m not sure what you mean when you say use. I’m assuming you want to change the target value of an operand within your ZPL macro. You can do this with the SETOPERAND keyword:
SETOPERAND row, col, value
You need to give it the operand row number, the col is 8 for the target value, and value is the new target. Here’s an example for you:
Let me know if that’s what you were looking for. Take care,
  • Jan 31, 2022 10:00 AM UTC
Hi Ralf,
  • Jan 31, 2022 1:16 PM UTC
DearDavid,
thanks for your answer. That helps a lot.
Best regards
Ralf
