Retrieve current object number in NS with macro
I would like to retrieve current object number in Macro while I choose ZPL macro in solveing type of x position in  pure NS editor.
I check Manual and found there is a function that can get the object number.
NPRO(surf, object, code,face), but the object parameter  in this function is object number which is what I want to retrieve.
How can I retrieve current object number in NS mode while I write ZPL code?
Best regards
Kevin
Hi Kevin,
I'm not on my work's laptop, and don't have access to the Help File, but I believe the numeric function you need is:
SOSO(1)
Note that you can change the argument to zero for the sequential surface number.
NPRO is to retrieve non-sequential object parameters, and not the object number itself. The object number is in fact an argument of this numeric function.
Let me know if this helps.
  • April 2, 2021
Hi David,
It works
thanks
kevin
