read data from geometric image analyze in a macro
  • Apr 26, 2024 7:45 AM UTC
  • 264 views
Fredrik valfridsson
To speed up a macro I need to read out data from certain pixels from the geometric image analyze in a macro.
how do i do that
Best answer by yuan.chen
Hi Fredrik, you get use the sample code below to extract the efficiency, it’s similar to go to the desired line. However, I am not sure if it’s the most efficient way.
! Get a temporary file name
A$ = $TEMPFILENAME()
! Compute the data and place in the temp file
GETTEXTFILE A$, Ima
! Open the new file and print it out
OPEN A$
for i,1,27,1
READSKIP -2
i = i+1
next
Read A,B,C,D
print D
yuan.chen
  • Apr 29, 2024 2:54 AM UTC
GETTEXTFILE A$, Ima
OPEN A$
for i,1,27,1
READSKIP -2
i = i+1
next
Read A,B,C,D
print D
Fredrik valfridsson
thank you yuan
this helped
depending on how many rays I use this fastened up my macro a lot
