how to force an analysis window to read a changed/modified config file
  • June 21, 2020
  • 208 views
I have a lens file open, with some analysis windows open.  Using ZPL, I want to loop through and change the .CFG file (this is for a detector window in non-sequential.).   I haven't done it yet, but I think this will change the settings:
         ModifySettings (filename,DVW_FILTER, ‘new_filter_string”, ‘DVR’) , or something like that, once I get the quotes straightened out.
    However, my question is:  How do I force the open analysis window to update with the new .cfg file? In ZPL Macro, there does not seem to be any command like:  LoadNewConfig(Filename, WindowNumber).
   I know I might be able to open a new analysis window, but for reasons of being able to see what is going on, I'll save that for Option B.
thanks for your time.
John
  • 911 replies
  • June 21, 2020
ModifySettings will work like you think, but it will not modify the settings of an already open window. You'll need to use OPENWINDOW to create a new instance that uses your new congiguration. Fortunately, there's also CLOSEWINDOW so that you don't get windows croding your screen.
- M
