How do I retrieve coordinate break tilt about x data using GETVARDATA operand in a ZPL macro?
  • December 23, 2022
  • 550 views
How do I retrieve coordinate break value (Tilt About X) from a particular surface number using GETVARDATA operand in a ZPL macro?
Hi Victoria,
 I don’t think you can easily specify the surface number with this method. Instead, GETVARDATA works on the number of variables. Here is a dummy example:
In this example, I have 3 variables: Decenter X, Decenter Y, and Tilt About X. Tilt About X is the third variable. Therefore, I can use the following ZPL macro:
# Get variable data in VEC1
GETVARDATA 1
# Print third variable value (3 x 5 = 15)
print VEC1(15)
Variable values are multiples of five. 5 is the value of the first variable, 10 the second, and 15 the third, as documented in the Help File (The Programming Tab > About the ZPL > KEYWORDS (about the zpl) > GETVARDATA). The result is as follow:
If you want the Tilt About X parameter of a specific Coordinate Break surface, why don’t you use the numeric function PARM(<parameter_number>, <surface_number>). This function returns the specified surface parameter value. In the same dummy example you can simply write:
PRINT PARM(3, 2)
And it should give you the same result. Note that 3 is the parameter number ( Tilt About X ) and 2 is the surface number.
GETVARDATA returns the surface number associated with each variable, and you could have a for loop that checks whether it matches your specified surface, something like so:
# Target Surface
surface = 2
# Target Parameter
parameter = 3
# Number of variables
num_of_var = VEC1(0)
# Loop over all variables data
FOR ii, 1, num_of_var, 1
# Surface of variable
surf_of_var = VEC1( ii * 5 - 3 )
# Parameter of variable
par_of_var = VEC1( ii * 5 - 2 )
# Test if surface and parameter match
IF ( surface == surf_of_var )
IF ( parameter == par_of_var )
# Print matching variable value
FORMAT 2 INT
PRINT "Surface ", surface,
PRINT ", Parameter ", parameter,
FORMAT 5.5
PRINT ": ", VEC1( ii * 5 )
ENDIF
ENDIF
NEXT
But I think its quite heavier than PARM.
I hope this helps.
  • December 24, 2022
Hi Victoria,
GETVARDATA 1
print VEC1(15)
PRINT PARM(3, 2)
# Target Surface
surface = 2
# Target Parameter
parameter = 3
FORMAT 2 INT
FORMAT 5.5
ENDIF
ENDIF
NEXT
I hope this helps.
  • January 4, 2023
Thank you!
