Geometric ESF vs FFT ESF
  • Feb 13, 2023 7:21 AM UTC
  • 421 views
sh0815kang
In otpicstudion I am using, there are two way to get edge spread function.
One is gemetric ESF, and the other is FFT ESF.
I guess that FFT ESF are based on FFT, but don't know how the geometric ESF is calculated.
Is it based on raytrace method rather than wave property of light?
Best answer by MichaelH
To add to Jeff’s answer, the Geometric ESF uses the spot diagram to calculate the edge spread function while the FFT ESF uses the FFT PSF to calculate the edge spread function.  Mathematically, the calculation is the same as explained in Jeff’s excerpt “the line spread function is determined by integrating the spot diagram in one direction” (where the spot diagram is either the Geometric Spot Diagram or the FFT PSF).
The FFT ESF accounts for diffraction and should be used if the Spot Diagram is smaller than the Airy Disk or the wavefront is less than 1/4 waves; otherwise the Geometric ESF should be used.
  • Feb 13, 2023 7:54 PM UTC
Take a look at Sections 11.8 and 11.9 in Modern Optical Engineering 3rd Ed., by Warren Smith.  I’ve attached a couple of pages that explain how the geometric Line Spread Function (LSF) is calculated from a ray-tracing spot diagram.  This is obviously an approach based on geometrical optics, so diffraction is ignored.  It should provide a good approximation when the optical system is not diffraction limited (i.e., when aberrations dominate the point spread function).  The ESF is simply the integral of the LSF.
  • Feb 14, 2023 6:10 PM UTC
