float to integer
  • Sep 23, 2024 9:09 AM UTC
  • 245 views
Is there a way to change variable from float to integer?
I want to use it to write list of polygons in loop:
for i:n:
polygon_name 1.pob
polygon_name 2.pob
polygon_name 3.pob
In other words, i dont want something like that:
Nadav
Best answer by Sean Turner
Use the FORMAT keyword to change to an integer.
FORMAT m INT
The optional keyword INT indicates the value should be first converted to an integer and printed in integer format using the number of places specified by m.
Sean Turner
  • Sep 23, 2024 12:40 PM UTC
FORMAT m INT
  • Sep 23, 2024 1:17 PM UTC
Hi Sean,
It works,
Thank you very much,
Nadav
