FLDX obsolete
  • Jan 26, 2021 5:19 PM UTC
  • 155 views
Christoph.Bodendorf
I am using FLDX,FLDY to get the current field angle.
Now, I find in the Help: These commands are obsolete. See “SETSYSTEMPROPERTY, SYSP”.
But SETSYSTEMPROPERTY is to *set* properties of the system, not to *read* them. So how do I access the current field angle now?
     Christof.
Hui Chen
  • Jan 26, 2021 6:50 PM UTC
Hi Christof,
Thank you for your post!
To 'read' the field value from current field data editor, you should use Numeric Function instead. There are two numeric functions, FLDX() and FLDY() that will return the field values from the Field Data Editor. You can find this described in the Help File at The Programming Tab > About the ZPL > Numeric Functions
Let me know if you have any questions.
Hui
Christoph.Bodendorf
Hi Hui,
Yes FLDX() and FLDY() are exactly the numeric functions I am using. I found them in an old script of mine. When I wanted to remind myself on the use of these functions, I found in the help that they are obsolete. So I guess there once was a keyword FLDX without () which is obsolete, while the function FLDX() is not obsolete.
Thank you and best regards,
Christof.
