CodeV to opticsStudioConverter-ZPL latest file! Version: 2.06.4 ! August 28, 2019
  • June 3, 2021
  • 177 views
Need to convert from codeV to Zemax. Can you please provide the latest CodeV to opticsStudioConverter.ZPL macro. The current file is working properly. Following error
0098    SCC C6 0
No mapping for command SCC
0098    Nothing to convert
! Version: 2.06.4
! August 28, 2019
! NOTE: This Macro constructs Zemax OS Optical system using Code V seq file
1333    PIK   SCO S14 Z2 C8 SCO S14 Z1 C8 1.00162632102796
No mapping for command PIK
1333    Nothing to convert
1334    PIK   SCO S14 Z2 C9 SCO S14 Z1 C9 1.00162632102796
1334    Nothing to convert
1335    PIK   SCO S14 Z2 C10 SCO S14 Z1 C10 1.00162632102796
1335    Nothing to convert
1336    PIK   SCO S14 Z2 C11 SCO S14 Z1 C11 1.00162632102796
1336    Nothing to convert
1337    PIK   SCO S14 Z2 C12 SCO S14 Z1 C12 1.00162632102796
1337    Nothing to convert
1338    PIK   SCO S14 Z3 C2 SCO S14 Z1 C2 1.003255286976006
1338    Nothing to convert
1339    PIK   SCO S14 Z3 C4 SCO S14 Z1 C4 1.003255286976006
1339    Nothing to convert
1340    PIK   SCO S14 Z3 C5 SCO S14 Z1 C5 1.003255286976006
1340    Nothing to convert
1341    PIK   SCO S14 Z3 C6 SCO S14 Z1 C6 1.003255286976006
1341    Nothing to convert
1342    PIK   SCO S14 Z3 C7 SCO S14 Z1 C7 1.003255286976006
1342    Nothing to convert
1343    PIK   SCO S14 Z3 C8 SCO S14 Z1 C8 1.003255286976006
1343    Nothing to convert
1344    PIK   SCO S14 Z3 C9 SCO S14 Z1 C9 1.003255286976006
1344    Nothing to convert
1345    PIK   SCO S14 Z3 C10 SCO S14 Z1 C10 1.003255286976006
1345    Nothing to convert
1346    PIK   SCO S14 Z3 C11 SCO S14 Z1 C11 1.003255286976006
1346    Nothing to convert
1347    PIK   SCO S14 Z3 C12 SCO S14 Z1 C12 1.003255286976006
1347    Nothing to convert
1348    PIK   SCO S15 Z2 C2 SCO S15 Z1 C2 1.00162632102796
1348    Nothing to convert
1349    PIK   SCO S15 Z2 C4 SCO S15 Z1 C4 1.00162632102796
1349    Nothing to convert
1350    PIK   SCO S15 Z2 C5 SCO S15 Z1 C5 1.00162632102796
1350    Nothing to convert
1351    PIK   SCO S15 Z2 C6 SCO S15 Z1 C6 1.00162632102796
1351    Nothing to convert
1352    PIK   SCO S15 Z2 C7 SCO S15 Z1 C7 1.00162632102796
1352    Nothing to convert
1353    PIK   SCO S15 Z2 C8 SCO S15 Z1 C8 1.00162632102796
1353    Nothing to convert
1354    PIK   SCO S15 Z2 C9 SCO S15 Z1 C9 1.00162632102796
1354    Nothing to convert
1355    PIK   SCO S15 Z2 C10 SCO S15 Z1 C10 1.00162632102796
1355    Nothing to convert
1356    PIK   SCO S15 Z2 C11 SCO S15 Z1 C11 1.00162632102796
1356    Nothing to convert
1357    PIK   SCO S15 Z2 C12 SCO S15 Z1 C12 1.00162632102796
1357    Nothing to convert
1358    PIK   SCO S15 Z3 C2 SCO S15 Z1 C2 1.003255286976006
1358    Nothing to convert
1359    PIK   SCO S15 Z3 C4 SCO S15 Z1 C4 1.003255286976006
1359    Nothing to convert
Hi Helen,
I am not sure if you got my last reply to your original thread but I was asking if you could share with us your Code V file with us? You can open a case or send an email. Let us know if you can't share your file at all and I'll check with my colleague that is in charge of the macro.
Thank you.
Sandrine
