ZOS-API material model Python
  • May 30, 2024
  • 301 views
fabian358
I was trying to set the material model properties through Python API but it did not work. The result I get is implementation of material model to my Zemax modelm but with the refractive index of 0. Could you help me with this?
Thank you in advance!
The code I use is visible below:
materialModel = surface.MaterialCell.CreateSolveType(ZOSAPI.Editors.SolveType.MaterialModel)
materialModel.IndexNd = 1.33
materialModel.AbbeVd = 5
surface.MaterialCell.SetSolveData(materialModel)
Best wishes,
Fabian
chaasjes
  • Visible
  • May 30, 2024
Hi @fabian358,
You need to use the _S_MaterialModel property of the SolveData object:
materialModel = surface.MaterialCell.CreateSolveType(ZOSAPI.Editors.SolveType.MaterialModel)._S_MaterialModel
If you want an easier way to set the material model (and other solve types), you can check out ZOSPy, which reduces this to a single function call:
import zospy as zp
zp.solvers.material_model(
surface.MaterialCell,
refractive_index=1.33,
abbe_number=5
