ZOS-API How to save Zemax file as lens project to a folder
Typically I would only save the Zemax file as below for later use
TheSystem.SaveAs(r"C:\Path\To\Save\MyLens.zmx")
Is there a way to save the Zemax file as a Lens Project to a folder? With all the dependencies pointed to the folder root? Such as: GLASSCAT, COATING, CONFIG, etc.?
Thanks
  • August 21, 2025
This is done at the IOpticalSystem level, so if you want to set a file as a project directory, you should use:
TheSystem.ConvertToProjectDirectory(folder_path)
print(TheSystem.IsProjectDirectory)
If you want to turn off the project directory, you can use:
TheSystem.TurnOffProjectDirectory()
  • August 22, 2025
​@MichaelH Nice! But once I save the system to Project Directory - how do I set all dependencies/sources to the Lens Project Root Folder?
Similar to this action in  the GUI.
-Asuku
