ZOS-API - access to "Clear Vignetting" and "Set Vignetting" with Python
  • Jan 5, 2024 12:19 AM UTC
  • 320 views
YuY
I’m trying to clear the vignetting and recalculate the vignetting by using the “Set Vignetting” and “Clear Vignetting” in the System explorer. I’m wondering if this accessible in zosapi?
@YuY
I believe those two features are accessed in the ZOS-API with:
TheSystem.SystemData.Fields.SetVignetting()
TheSystem.SystemData.Fields.ClearVignetting()
Regarding the FFT MTF settings. I would advise to start a new topic if the question does not fall within the context of the initial topic. That being said, I believe the issue is related to this:
Can you try changing this line of code:
newWin_Settings = newWin.GetSettings()
With this new one:
newWin_Settings = newWin.GetSettings().__implementation__
Notice the __implementation__ at the end. It should fix the issue. Let us know otherwise.
YuY
  • Jan 5, 2024 5:32 AM UTC
Additionally,
I found that the fftMTF setting sample script doesn’t work.
# SettingsnewWin_Settings = newWin.GetSettings()newWin_Settings.MaximumFrequency = 50newWin_Settings.SampleSize = ZOSAPI.Analysis.SampleSizes.S_256x256
the max frequency and the sample size remains the same.
  • Jan 5, 2024 10:13 AM UTC
@YuY
With this new one:
