Updating Spot Diagram
  • June 10, 2025
  • 133 views
Matt H
The ray density of the spot diagram is not being updated as expected; I have tried two different methods:
# spot diagram
spot = TheSystem.Analyses.New_StandardSpot()
spot.GetSettings.RayDensity = 15
spot.ApplyAndWaitForCompletion()
newSpot = TheSystem.Analyses.New_StandardSpot()
print("Spot has analysis specific settings? ", newSpot.HasAnalysisSpecificSettings) # True; no ModifySettings
newSettings = newSpot.GetSettings()
newSettings.RayDensity = 15
newSpot.ApplyAndWaitForCompletion()
However, after being run the ray density of the spot diagram does not update as expected - any ideas?
@Matt H
The first snippet doesn't work because you are missing parentheses for your GetSettings() call.
The second one should work, but then there’s this:
If you don’t want to read the long post and have a quick fix, try:
newSettings = newSpot.GetSettings().__implementation__
