Unable to establish ZOS API connection to Python since Update to 2026R1.01
  • June 5, 2026
  • 5 replies
  • 228 views
Dear all,
I updated this morning to Zemax 2026 R1.01. Since then I get the following error message when trying to connect to Zemax with Python via API (e.g. by using the PythonStandAlone_01.py file):
“InitializationException: Unable to locate Zemax OpticStudio.  Try using a hard-coded path.”
Did anything change here?
Thank you and best regards,
Gregor
@Gregor
I haven’t installed 2026 R1.01, but I’ve read about similar topics in the past and reinstalling OpticStudio was often enough to solve the issue.
That being said, have you tried using a hard-coded path like the error suggests?
The message is a bit cryptic, but the code is looking for the API library files, usually in \Documents\Zemax\ZOS-API\Libraries (maybe also check that this folder exists for you and that it has files like ZOSAPI_NetHelper.dll) but the way it finds it is through lines like:
# determine location of ZOSAPI_NetHelper.dll & add as reference
aKey = winreg.OpenKey(winreg.ConnectRegistry(None, winreg.HKEY_CURRENT_USER), r"Software\Zemax", 0, winreg.KEY_READ)
zemaxData = winreg.QueryValueEx(aKey, 'ZemaxRoot')
NetHelper = os.path.join(os.sep, zemaxData[0], r'ZOS-API\Libraries\ZOSAPI_NetHelper.dll')
where it is looking for a key in the Windows Registry (ZemaxRoot), if that key gets messed up for whatever reason, it can explain the error.
Instead of this line:
You could try to supply a hard-coded path:
NetHelper = r'C:\Users\your_username\Documents\Zemax\ZOS-API\Libraries\ZOSAPI_NetHelper.dll'
Sorry I don’t have a definite answer, hopefully it helps. The ZOSPy folks might be able to help further ​@chaasjes ​@jwbeenakker.
Omni
  • June 5, 2026
Hi, are you using in extension mode or standalone mode? or both!
  • June 5, 2026
I get the same message for both, extension and standalone. Looks like as if the path to something got lost.
  • June 9, 2026
@Gregor
Omni
  • June 12, 2026
Thanks David,
your solution works.
Thanks a lot,
Gregor
By the way, when you reinstall OpticStudio that is also what’s happening. The registry key is overwritten with the potentially correct path. But if you know what you are doing, supplying the path is perhaps the more lightweight approach.
