Unable to connect Python (Spyder) to Zemax
  • Dec 23, 2022 9:12 AM UTC
  • 6 replies
  • 505 views
Hi ,
I am currently trying to use python (Spyder) to connect with Zemax.
But I am getting the errors below (shown in the picture below) . I can’t find any solution.
I tried to use another python version - 3.7.0 , but still same error. Both standalone application and interactive extension result in same error messages.
Appreciate if anyone could give me some guidance. Thank you
Hi @Eric.Aw
I had a similar problem and this post helped me: https://stackoverflow.com/questions/47913079/python-attributeerror-module-object-has-no-attribute-addreference
Hi Eric,
I’m assuming you are generating the tepmlate code from the latest OpticStudio version: Programming > Python > Standalone Application / Interactive Extension.
Can you tell us your version of Pythonnet as well? There have been issues with Pythonnet 3.0.0 and Zemax recommend using Pythonnet 2.5.2 for the moment:
  • Dec 28, 2022 2:11 AM UTC
Hi David,
Thank you for the advice. Yes, I am generating the template from that method.
I have uninstall Pythonnet 3.0.0 and installed 2.5.2. However, the error continue to occur.
Is there any other method/way I could try ?
Ethan
  • Jan 13, 2023 4:11 AM UTC
Hi @Eric.Aw,
I’m wondering if you are missing a required package for Python. In order for clr to work properly, you need to install the Pythonnet library. It could be corrupted as well, so try uninstalling/reinstalling it if you’ve already added it to your Python installation.
There are also some good suggestions here in this Community article: ZOSAPI_NetHelper cannot be added | Zemax Community.
Ethan
  • Jan 31, 2023 1:30 AM UTC
Hi @Ethan , @Sandrine Auriol
Thank you very much for the advice.
At the end , I uninstall everything (python and spyder) and install everything again. Then follow some of the guide above and it works.
Thank you
Ethan
  • Jan 31, 2023 5:32 PM UTC
Hi @Eric.Aw,
I’m glad to hear you got it working! Thanks for updating the Community with your findings.
Ethan
