Setting tilts and decenter solves as variable in ZOS-API
  • January 7, 2025
  • 92 views
Daniel P. Calero
I am trying to set some coordinate breaks X-Y tilts as variable using ZOS-API in Matlab.
for thickness I know that the code is:
Surface1.ThicknessCell.MakeSolveVariable();
I tried different approaches, but nothing worked so far.
Daniel P. Calero
  • 7 replies
  • January 7, 2025
I solved it;
the text should be
Surface1.SurfaceData.Par3.MakeSolveVariable();
