Optimizing complex shapes in non-sequential mode
  • April 30, 2021
  • 483 views
c​hris
We had an idea to optimize shapes parameterized by low-degree polynomials (or other shapes: ellipsoids, etc.). We want to maximize irradiance across a complex mesh detector (STL) by modifying another complex, not-radially-symmetric, surface.
From what I saw, the TrueFreeForm object isn't supported in non-sequential mode, and the Freeform-Z object limits the shape to a cylinder-like shape that varies in diameter.
Can we accomplish our goal using built-in OpticStudio stuff that I haven't seen yet? Or will we need to write our own stuff that generates meshes and runs the optimization? We have the means I think, I just didn't want to jump in if you had already solved this problem :)
Hi Chris
Yes the TrueFreeform object is not supported in non-sequential mode and the Freeform-Z object is a profile that is then rotated around Z.
In non-sequential mode, the objects with the most flexibility but not static are the Extended Polynomial Lens/Surface, Biconic Zernike Surface/Lens.
Sandrine
Hi Chris
Sandrine
Ana .Manzanares
Is it possible to make the design in SQ mode using a TrueFreeForm surface, export the lens as CAD and use it in NSQ mode?
Thanks in advance.
Ana.
