Matlab ZOS Connection returns "License Check Failed"
  • October 14, 2019
  • 533 views
I am running OpticStudio Professional (19.4) using a black USB key with with support expiring in Decemeber.  When I try to connect using a Matlab ZOS interactive extension it fails the license check.  What can I do about this.
I suppose I could run it standalone in debug mode...  Other ideas?
Thanks.
Best answer by David Nguyen
Hi Alan,
Are you aware that the MATLAB interactive extension has to be initiated from OpticStudio itself? This means you need to press Interactive Extension from the Programming tab of OpticStudio before running the interactive extension boilerplate code.
This should open a window that will listen for the communication with MATLAB.
Once this has been done, you can execute the MATLAB interactive extension boilerplate code without error.
Please let me know if this works for you.
Kind regards,
  • October 14, 2019
Serial Number 26505.
David Nguyen
  • October 15, 2019
Hi Alan,
Kind regards,
joshdfreeman
  • November 27, 2021
Worked for me.. ! Thanks for posting.
