import zosapi crashes jupyter kernel, how can I fix it?
  • July 13, 2022
  • 221 views
Hello!
I’m attempting to use the ZOS-API in Python (3.8.13). I’ve been running my code from the terminal window and have successfully executed a batch ray trace. I’m working on something that could benefit from using an interactive environment, so I am trying to use a Jupyter notebook or interactive cells in VS code.
When I try to run <import zosapi> the kernel dies immediately. One of the errors thrown is
“Unhandled Exeption: System.IO.FileNotFoundException: Could not load file or assembly ‘ZOSAPI_Interfaces, Version=1.0.0.0, Culture=Neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified”
Am I missing a ZOSAPI_Interfaces file? Has anyone encountered this error before?
Jaren
Best answer by MichaelH
Hi Jaren,
Also, are you using Jupyter or JupyterLab?  How did you install Jupyter/JupyterLab?  Did you install both zosapi and jupyter from pip with the same installation of Python or are you using an IDE to install Jupyter/JupyterLab?
Allie
  • July 14, 2022
Hi Jaren!
Could you share a snippet of your code so I see how you are loading and defining the API? It sounds like you are using the Python zosapi library instead of the pre-provided boilerplate, but I want to make sure. It would be useful to see everything up to your definition of TheSystem.
  • July 14, 2022
Hi Jaren,
Hi pardon me for responding so late, just got a notification that the above comment was chosen as the best answer.
I was just using jupyter, though the same behavior is seen when I use Jupyterlab and ipython notebooks in VS Code. All were installed with the Anaconda navigator, and I pip installed the zosapi in the same conda environment.
