How to read Quick Sensitivity results with ZOS API
  • April 20, 2026
  • 91 views
mocquin
When trying to extract results from a Quick Sensitivity, either ran with GUI or API, I get the same message :
tol_data_viewer = zos.system.Tools.OpenToleranceDataViewer()
tol_data_viewer.FileName = r"C:\full_path_to\quick_sens.ZTD"
tol_data_viewer.RunAndWaitForCompletion()
if not tol_data_viewer.Succeeded:
print(tol_data_viewer.ErrorMessage)
tol_data_viewer.Close()
cannot parse Sensitivity data: L'index se trouve en dehors des limites du tableau.
Are results from quick sentitivity supposed to be compatible with the read of the API ? because it is compatible in the GUI
  • April 21, 2026
@mocquin
I tried your code with a dummy quick analysis (on the Double Gauss sample file), and it seems to work for me. Nothing gets printed (and I get a summary like in the UI). I used 2026 R1 with ZOSPy:
Python=3.11.15
ZOSPy=2.1.5
Pythonnet=3.0.5
Are you able to share your file?
