How to load Spectrum File in Color/Spectrum of object properties in ZOS API Matlab and Python
  • Feb 23, 2022 11:36 PM UTC
  • 463 views
Sahil
In OpticStudio, We can load any spectrum file from our   \Objects\Sources\Spectrum Files Folder .Here is the available code for Matlab and Python. You can use this code in Standalone or Interactive Extension.
-Copy the code in your file .
-Change the path of testfile
Matlab Code:
import ZOSAPI.*;
sampleDir = TheApplication.SamplesDir;
testFile = System.String.Concat("C:\test\ZPO\Diode sample.ZMX");
NSCE = TheSystem.NCE;
Obj1 = NSCE.GetObjectAt(1);
Source_Color=Obj1.SourcesData.SourceColor;
Source_Color=ZOSAPI.Editors.NCE.SourceColorMode.SpectrumFile;
filesAvailable = Obj1.SourcesData.SourceColorSettings.GetAvailableSpectrumFiles();
FileToSelect=filesAvailable(6);
Obj1.SourcesData.SourceColorSettings.SpectrumFile=FileToSelect;
Matlab Interactive Extension
Python Code:
testFile = r"C:\test\ZPO\Diode sample.ZMX"
TheSystem.LoadFile(testFile, False)
print(TheSystem.SystemFile)
Obj1.SourcesData.SourceColorSettings.SpectrumFile=filesAvailable[1]
print(Obj1.SourcesData.SourceColorSettings.SpectrumFile)
Python Interactive Extension
  • Feb 26, 2024 3:04 PM UTC
This method appears to be deprecated. I could only do it by accessing private variables.
NSE = TheSystem.NCE
obj_1 = NSE.GetObjectAt(1)
available_source_files = obj_1.SourcesData.SourceColorSettings._S_SpectrumFile.GetAvailableSpectrumFiles()
obj_1.SourcesData.SourceColorSettings._S_SpectrumFile.set_SpectrumFile(available_source_files)
print(f"Spectrum set: {obj_1.SourcesData.SourceColorSettings._S_SpectrumFile.get_SpectrumFile()}")
Is there a cleaner way?
Thomas
