How to load a Prescription Data Report into a Matlab struct?
  • May 19, 2020 9:06 AM UTC
  • 331 views
Is there a way to get the Prescription Data Report using the Matlab ZOS_API?
I've been trying:
prescriptionData = ZOSAPI.Analysis.AnalysisIDM.PrescriptionDataSettings;
But that seems to return an 'AnalysisIDM' object.
My goal is to have the Prescription data as a struct but just a text file like the Report generated from the Analyze Tab would be great.
Thank you for your time!
Best answer by Victor.Haase-Coelho
The solution I used:
TheSystem = app.PrimarySystem;
prescriptionReport = TheSystem.Analyses.New_Analysis(ZOSAPI.Analysis.AnalysisIDM.PrescriptionDataSettings);
prescriptionReport.ApplyAndWaitForCompletion();
prescriptionResults = prescriptionReport.GetResults();
prescriptionResults.GetTextFile(System.String.Concat(strcat(filesDir, strcat('PrescriptionDataReport_',file,'.txt'))));
This is pretty much copied from Example 10.
I can then open the text file from within Matlab.
Please let me know if there is a better way.
