How can I use "Test Plate Fitting via ZOS-API and Python
  • Feb 15, 2024 1:07 PM UTC
  • 192 views
Ascho
Is it possible to use “Testplatefitting via ZOS-API and python?
Thanks, Anja
@Ascho
I don’t think it is possible. The only mention of “plate” in the ZOS-API Syntax Help File is about the Test Plate List, which you could open with:
TheSystem.Analyses.New_Analysis(ZOSAPI.Analysis.AnalysisIDM.TestPlateList)
Since you’d have the values to test against. You could create the algorithm in Python, but it might be more work than you want.
Alternatively, ZPL seem to have a keyword TESTPLATEFIT that calls the test plate fitting routine.
  • May 8, 2024 7:18 AM UTC
@Ascho
Ascho
  • May 8, 2024 7:45 AM UTC
Hi David,
thanks for your answer. As you recommended, I solved my problem by using an own algorithm in Python.
My algorithm takes more time, but it was more helpful for my specific problem.
Best regards
Anja
@Ascho
Great to hear. If you'd be willing to share your implementation with others you could consider contributing it to ZOSPy. I think@jwbeenakker can give more details if you are interested :)
