Error using ZOS-API in Matlab
  • January 22, 2025
  • 11 replies
  • 1102 views
My codes (that were working with the 2024 version) do not work anymore with the 2025 release.
this is the error I get in the function “InitConnection()”:
Message: Could not load file or assembly 'ZemaxEngine.dll' or one of its dependencies. The dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A)
Source: mscorlib
HelpLink: None
Best answer by Julia
Hi bostanem,
I just updated my Matlab to Update5, I experience no error with this version.
Prasath R
  • January 24, 2025
Hi Luca,
You might want to try changing the directory mentioned in this post. Hopefully, it will help.
Matlab examples failing to connect to OpticStudio | Zemax Community
  • January 29, 2025
That part of the code works well, the error appears when I try to execute the line
app = TheConnection.CreateNewApplication()
NicoloAzzaroli
I have exactly the same issue.
Waiting for a solution from Zemax
Julia
  • February 7, 2025
Hi all,
Updating MATLAB to the latest version should resolve this issue. Please try updating and let us know how it goes.
下载 MATLAB、Simulink、Stateflow 和其他 MathWorks 产品
Julia
bostanem
  • March 18, 2025
Hi all,
I am facing the same problem and updating to the latest Matlab (ie version R2024b) did not solve the problem. The method CreateNewApplication()results in the same error:
Message: Could not load file or assembly 'ZemaxEngine.dll' or one of its dependencies. A dynamic link library
Source: mscorlib
HelpLink: None
FYI, I am using OpticStudio 2025.
Julia
  • March 18, 2025
Hi bostanem,
Would you please try the version below?
Julia
bostanem
  • March 18, 2025
Hi Julia,
Thanks a lot. It seems that I can install Update 5 (and not 4). Would that be okay?
Julia
  • March 18, 2025
Hi bostanem,
bostanem
  • March 18, 2025
Thanks Julia, this seems to fix the issue for me. I appreciate your help.
  • April 29, 2025
Date: April 29, 2025.
The latest available from Matlab is now R2024b, update 6 (not 5).   When I install update 6 of Matlab, I have the same problem, using the sample scripts from Zemax:
success = ZOSAPI_NetHelper.ZOSAPI_Initializer.Initialize();
returns 0 instead of a 1.
Prasath R
  • May 18, 2025
Hi Bowen,
Thank you for your update in the forum post. I'm sharing it here for the reference of other users.
ZOS-API Initialization Error in Matlab | Zemax Community
