Difference between GetAllDetectorData() and GetAllDetectorDataSafe()
  • Apr 4, 2023 9:13 AM UTC
  • 419 views
Julia
GetAllDetectorData() and GetAllDetectorDataSafe() are both methods that can be used to retrieve detector data for a specified detector object.
  1. The main difference between the two methods is that GetAllDetectorDataSafe() returns a two-dimensional array of double values double[,] that contains all the detector data for the detector object, while GetAllDetectorData() returns a boolean value that indicates whether the detector data was retrieved successfully, and one-dimensional array double[] .
  2. GetAllDetectorDataSafe() does not require the input of numPixels and detectorData, whereas GetAllDetectorData() requires these parameters in addition to (detector) ObjectNumber and Data(type).
Check the examples to use the two methods:
For python:
TheNCE = TheSystem.NCE
DetObj = 4
obj = TheSystem.NCE.GetObjectAt(DetObj);
numXPixels = obj.ObjectData.NumberXPixels;
numYPixels = obj.ObjectData.NumberYPixels;
DetRectangleData_FluxArea = TheSystem.NCE.GetAllDetectorDataSafe(4, 1)
for x in range(numXPixels):
for y in range(numYPixels):
print(DetRectangleData_FluxArea[x,y])
numPixels=numXPixels*numYPixels
detectorData=np.zeros(numPixels, dtype=np.float64)
bool_value, detectorData= TheNCE.GetAllDetectorData(DetObj, 1, numPixels,detectorData)
for i in range(numPixels):
print(detectorData[i])
For matlab:
TheNCE = TheSystem.NCE;
DetObj = 4;
DetRectangleData_FluxArea = TheSystem.NCE.GetAllDetectorDataSafe(4, 1);
for x = 1:numXPixels
for y = 1:numYPixels
disp(DetRectangleData_FluxArea(x,y));
end
end
numPixels=numXPixels*numYPixels;
detectorData=NET.createArray('System.Double', TheNCE.GetDetectorSize(4));
bool_value=TheSystem.NCE.GetAllDetectorData(DetObj, 1,TheNCE.GetDetectorSize(4),detectorData);
for i = 1:numPixels
disp(detectorData(i));
end
In matlab, the retrieved data from GetAllDetectorData() need to be rearranged from 1D array to a matrix, detectorData = flipud(rot90(reshape(data.double, rows, cols)));
and here is a simple example to show the transform:
Julia
  • May 31, 2023 10:34 AM UTC
If the detector pattern is not symmetric or the X/Y pixels are not the same, use (in Matlab):
[~, rows, cols] = TheNCE.GetDetectorDimensions(4);
detectorData = flipud(rot90(reshape(data.double, cols, rows)));
% Create new figure figure;
figure;
surf(detectorData);
axis([1 cols 1 rows]);
view(2);
xlabel('X pixel');
ylabel('Y pixel');
title('Incoherent Illuminance [lm/cm^2]');
colorbar;
