API system parameter tracking
  • August 10, 2022
  • 106 views
redbottle
Hi
I am trying to track the x, y coordinates using API. I know in Macros I would just use the following:
SYSP 102, 1, x
SYSP 103, 1, y
anyone know how to pull these coordinates using API (Matlab) ?
Thanks!!
Hi redbottle,
The literal translation in Python would be:
# Define field number to be modified
FieldNumber = 1
# New field coordinates
Hx = 1.23
Hy = 2.34
# Retrieve corresponding field data
MyField = TheSystem.SystemData.Fields.GetField(FieldNumber)
# Update field coordinates
MyField.X = Hx
MyField.Y = Hy
I imagine this is the same in MATLAB. The variable Hx and Hy correspond to your variables x and y.
Let me know if this works for you.
  • August 11, 2022
Hi redbottle,
FieldNumber = 1
Hx = 1.23
Hy = 2.34
MyField.X = Hx
MyField.Y = Hy
redbottle
  • August 11, 2022
Thank you David! It works!
