API_Layout_plot_Python
  • November 11, 2023
  • 27 replies
  • 1360 views
Xianglei
API support for the Cross-Section, 3D Layout, and Shaded Models is added to the OpticStudio API.  The support allow users to change the settings via the API and retrieve a static image.  Layouts in both sequential and non-sequential mode are supported. Some toolbar buttons, such as automatically setting camera viewpoints, will also be accessible via the API.
Please download the following Python Standalone codes, including:
  1. PythonStandaloneApplication_SEQ_layout.py       (sequential mode and export 2D cross-section)
    • TheSystem.Tools.OpenCrossSectionExport()   # the core command
  2. PythonStandaloneApplication_SEQ_3DViewer.py (sequential mode and export 3D viewer)
    • TheSystem.Tools.Open3DViewerExport()
  3. PythonStandaloneApplication_SEQ_ShadedModel.py (sequential mode and export shaded model)
    • TheSystem.Tools.OpenShadedModelExport()
  4. PythonStandaloneApplication_NSC_3D.py              (non-sequential mode and export 3D layout)
    • TheSystem.Tools.OpenNSC3DLayoutExport()
  5. PythonStandaloneApplication_NSC_ShadedModel.py (non-sequential mode and export shaded model)
    • TheSystem.Tools.OpenNSCShadedModelExport()
Let us use 2D cross-section image export as one example: here is the setting window of cross-section layout.
Now you can use API to access these settings:
    TheSystem = TheApplication.PrimarySystem
    TheSystem.LoadFile(r"C:\Users\test\Double Gauss 28 degree field\Double Gauss 28 degree field.zmx", False) #load the targeted OS file
Left panel of settings window
myLayout = TheSystem.Tools.Layouts.OpenCrossSectionExport()
myLayout.StartSurface = 1
myLayout.EndSurface = TheSystem.LDE.NumberOfSurfaces - 1
myLayout.NumberOfRays = 7
myLayout.YStretch = 1
myLayout.FletchRays = False  # or True
Right panel of settings window
myLayout.Wavelength = -1  # Note that -1 means all wavelength !!!
myLayout.Field = -1      # Note that -1 means all fields
# myLayout.ColorRaysBy = ZOSAPI.Tools.Layouts.ColorRaysByCrossSectionOptions.Fields        # choice 1
# myLayout.ColorRaysBy = ZOSAPI.Tools.Layouts.ColorRaysByCrossSectionOptions.Waves       # choice 2
myLayout.ColorRaysBy = ZOSAPI.Tools.Layouts.ColorRaysByCrossSectionOptions.Wavelength  # choice 3
myLayout.UpperPupil = 1
myLayout.LowerPupil = -1
myLayout.DeleteVignetted = False  # or True
myLayout.MarginalAndChiefRayOnly = False # or True
myLayout.SaveImageAsFile = True # or False (if you do not want to save the image)
myLayout.OutputFileName = r"C:\Users\test\Double Gauss 28 degree field_CS_5.jpeg"  # supported image format including jpeg, bmp, png.  # You select the path to save the exported image
myLayout.OutputPixelWidth =  1920 #  4096 and even bigger
myLayout.OutputPixelHeight = 1080 #  2400 and even bigger
Besides, the toolbar of Line Thickness is also supported:
# myLayout.SurfaceLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Thinnest
myLayout.SurfaceLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Standard
# myLayout.SurfaceLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Thick
# myLayout.SurfaceLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Thickest
# myLayout.RaysLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Thinnest
myLayout.RaysLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Standard
# myLayout.RaysLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Thick
# myLayout.RaysLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Thickest
Last but not least, the direct access of the R, G, and B data of exported image is supported also. For example, you could uncomment the following piece of code to obtain these data (i.e., rData, gData, bData). Note that you need to let  myLayout.SaveImageAsFile = False
   # if (myLayout.RunAndWaitForCompletion()):
    #     ImageExportData = myLayout.ImageExportData
    #     if ImageExportData is not None:
    #         pixel = ImageExportData.GetImagePixel(512, 512)
    #         print(f"Pixel 512x512: {pixel.R} {pixel.G} {pixel.B}")
    #         rData = [0] * (1920 * 1080)
    #         gData = [0] * (1920 * 1080)
    #         bData = [0] * (1920 * 1080)
    #         ImageExportData.FillValues(1920 * 1080, rData, gData, bData)
    #         pixels = ImageExportData.Values
    #         print(pixels[512, 512].ToString())
Hope you like this new object Layout under the Tools! Please feel free to modify the attached codes as you want, and please let us know if you have any questions.
Ansys Staff
  • Ansys Staff
  • November 11, 2023
This is one of the biggest updates to the ZOS-API since adding POP support (and maybe since launching in 2015).  This is SUCH a long time coming and will be amazingly helpful.
And just to be perfectly clear, this looks like it will be in the 2024 R1.0 release, so it’s not active yet.
Xianglei
  • November 12, 2023
Hi Michael,
Thank you very much for your clarification, yes it is for the 2024 R1 release.
Xianglei
Ansys Staff
  • Ansys Staff
  • November 14, 2023
Hi @Xianglei,
It looks like you are becoming the ZOS-API expert at Zemax so I’ll raise this request to you.
It’s probably too big of an ask for the 24R1 release, but another extremely frustrating aspect of the ZOS-API (which should actually be easier to for the developers to implement vs the Layout API) is you can’t get direct access to all 29 data points in a Non-Sequential ray trace without saving a ZRD file to disk and parsing this file (this is slow, sometimes problematic with read/write capabilities, and developers forget to delete the ZRD).
In the IBatchRayTrace interface, there are IRayTraceNSCData and IRayTraceNSCSourceData (they have the same out parameters with their ReadNextSegment methods).  The following are the lack of outputs for each interface compared to saving a full ZRD file:
  • out int hitFace
  • out RayStatus status
  • out int xybin
  • out int lmbin
  • out double xNorm
  • out double yNorm
  • out double zNorm
  • out double index
  • out double startingPhase
  • out double phaseOf
  • out double phaseAt
The lack of hitFace means we can’t do something like the NSC Sag Map, the lack of status means we can’t see if the ray has an error, the lack of xybin/lmbin means we can’t recreate a detector, the lack of Norm values means we can’t calculate the Angle of Incidence, and the lack of index means we can’t calculate optical path length.  All these values can be accessed via the ZRD but it would be extremely useful to add a ReadNextSegmentFull to the IRayTraceNSCData and IRayTraceNSCSourceData interfaces so we can access all these values without writing to disk.
  • November 16, 2023
@MichaelH I have been looking at this issue. I hope to have news soon. We are always trying to improve functionality. In the meantime, 24R1 has some new functionality that you probably will like. I will post about the new functionality when 24R1 is released.
Allie
  • November 16, 2023
Hi team - I’m temporarily hiding this post until the release. We can continue the discussion after 2024 R1 is publicly available :)
Xianglei
  • January 24, 2024
I put the summary codes for the sequential 3D viewer layout plot for those who want to check the commands quickly.
myLayout = TheSystem.Tools.Layouts.Open3DViewerExport()
myLayout.OutputFileName = r"C:\Users\xianliu\OneDrive - ANSYS, Inc\testing_OD\2023\6004\SEQ\Double Gauss 28 degree field_3DViewer.png" #bmp, jpeg
myLayout.Wavelength = -1  # 0 or -1 means all wavelength
myLayout.Field = -1      # Pass (10 gives the same result as 3)
myLayout.RayPattern = ZOSAPI.Tools.General.RayPatternType.XYFan    # XFan, YFan, Ring, List, Random, Grid
myLayout.ColorRaysBy = ZOSAPI.Tools.Layouts.ColorRaysByOptions.Fields    # Waves, Wavelength
myLayout.DeleteVignetted = True
myLayout.HideLensFaces = True
myLayout.HideLensEdges = True
myLayout.HideXBars = True
myLayout.DrawParaxialPupils = True
myLayout.DrawRealEntrancePupils = ZOSAPI.Tools.Layouts.RealPupilOptions.Pupils_Off # Pupils_4 Pupils_8 Pupils_16 Pupils_32
myLayout.DrawRealExitPupils = ZOSAPI.Tools.Layouts.RealPupilOptions.Pupils_Off, # Pupils_4 Pupils_8 Pupils_16 Pupils_32
myLayout.FletchRays = True
myLayout.SplitNSCRays = True
myLayout.ScatterNSCRays = True
myLayout.SurfaceLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Thinnest #  Thin , Standard Thick Thickest
myLayout.RaysLineThickness = ZOSAPI.Tools.Layouts.LineThicknessOptions.Thinnest # Thin , Standard Thick Thickest
myLayout.CameraViewpointAngleX = 0 #AngleY AngleZ
myLayout.ConfigurationAll = True  # Current
myLayout.ConfigurationOffsetX = 0 # OffsetY OffsetZ
myLayout.Close()
Xianglei
  • January 24, 2024
I put the summary codes for the sequential ShadeModel layout plot for those who want to check the commands quickly.
myLayout = TheSystem.Tools.Layouts.OpenShadedModelExport()
myLayout.OutputFileName = r"C:\Users\xianliu\OneDrive - ANSYS, Inc\testing_OD\2023\6004\SEQ\Double Gauss 28 degree field_Shaded.jpeg"
myLayout.NumberOfRays = 10
myLayout.OutputPixelWidth =  4096   #  1920
myLayout.OutputPixelHeight = 2410 #   1080
myLayout.Opacity = ZOSAPI.Tools.Layouts.OpacityOptions.Ignore        # Consider, All50Percent, Color12
myLayout.Background =ZOSAPI.Tools.Layouts.BackgroundOptions.White      # Black, Red, Gradient03
myLayout.Wavelength = 1  # 0 or -1 means all wavelength
myLayout.DrawSection = ZOSAPI.Tools.Layouts.DrawSectionOptions.P100 # P75 P50 P25
myLayout.AngularSegments = ZOSAPI.Tools.Layouts.NumberSegmentsOptions.S_8  # S_16 S_32 S_64 S_128
myLayout.RadialSegments = ZOSAPI.Tools.Layouts.NumberSegmentsOptions.S_8   # S_16 S_32 S_64 S_128
myLayout.Brightness = ZOSAPI.Tools.Layouts.BrightnessOptions.P10  # P50 P100
myLayout.Configuration = True # pass
myLayout.CameraViewpointAngleX = 0 # AngleY AngleZ
myLayout.Close()
Xianglei
  • January 24, 2024
I put the summary codes for the Non-sequential Shaded Model layout plot for those who want to check the commands quickly.
myLayout = TheSystem.Tools.Layouts.OpenNSCShadedModelExport()
myLayout.OutputFileName = r"C:\Users\xianliu\OneDrive - ANSYS, Inc\testing_OD\2023\6004\NSQ\Test2B_QCon_NONSEQ_Coated_ShadedModel_demo.png"
myLayout.DetectorPixelColorMode = ZOSAPI.Tools.Layouts.DetectorPixelColorOptions.DoNotColorIndividualPoints  # ByRaysOnLayout ByLastAnalysis
myLayout.Filter = None
myLayout.RayDatabase = None
myLayout.RayTrace = ZOSAPI.Tools.Layouts.RayTraceOptions.UseRays   # LightningTraceAvgWavelength, LightningTraceTrueColor, InverseFalseColorIrradiance
myLayout.DetectorDisplayMode =
ZOSAPI.Tools.Layouts.DetectorDisplayModeOptions.Consider # GreyScaleFlux, InverseGreyScaleFlux, FalseColorFlux, InverseFalseColorFlux, GreyScaleIrradiance, InverseGreyScaleIrradiance, FalseColorIrradiance
myLayout.ColorRaysBy = ZOSAPI.Tools.Layouts.ColorRaysByNSCOptions.SourceNumber   # WaveNumber, ConfigNumber, Wavelength, SegmentNumber
myLayout.Background = ZOSAPI.Tools.Layouts.BackgroundOptions.White     # Red, Black, Gradient10, Color24, DarkBlue
myLayout.Brightness = ZOSAPI.Tools.Layouts.BrightnessOptions.P10       # P50, P100
myLayout.Opacity = ZOSAPI.Tools.Layouts.OpacityOptions.All50Percent     # Ignore Consider
myLayout.CameraViewpointAngleX = 0 # CameraViewpointAngleY, CameraViewpointAngleZ
myLayout.UsePolarizaion = True
myLayout.ScatterNSCRays = False
myLayout.ConfigurationAll = True  # ConfigurationCurrent
myLayout.ConfigurationOffsetX = 0 # ConfigurationOffsetY, ConfigurationOffsetZ
myLayout.Close()
Xianglei
  • January 24, 2024
I put the summary codes for the Non-sequential 3D layout plot for those who want to check the commands quickly.
myLayout = TheSystem.Tools.Layouts.OpenNSC3DLayoutExport()
myLayout.OutputFileName = r"C:\Users\xianliu\OneDrive - ANSYS, Inc\testing_OD\2023\6004\NSQ\Test6B_QType0_NONSEQ_Coated_3D.png" # bmp, jpeg
myLayout.RayDatabase = NoneQ
myLayout.ConfigurationOffsetX = 0 # ConfigurationOffsetY ConfigurationOffsetZ
myLayout.Close()
Ansys Staff
  • Ansys Staff
  • January 24, 2024
Hey Xianglei,
Thanks for posting the detailed examples.
One immediate feedback about this implementation is we don’t have access to the Zoom or Pan capabilities.  Right now, the only way to control the Zoom or Pan of any layout is to use a mouse; this is saved in the ZDA file but you can’t precisely recreate the Zoom or Pan if you change specific settings (like First Surface or Last Surface) or if you open up a new window.
To make this feature complete, we need access to set the Zoom & Pan programmatically.  Hopefully this can be incorporated into a future update in the very near future.
Xianglei
  • January 25, 2024
Hey Michael,
Thank you very much for your inputs here, which is fantastic to add Zoom or Pan in the API.
Xianglei
nice feature. can I change size of axis marker and visualize size marker?
on taked picuture “size marker” hidden and “axis marker” relative small
in zemax:
in saved image
dgeorgiev
  • May 16, 2024
Hello @Xianglei,
In future release, do you think it would be possible to set the rays shown in the 3D viewer per API?
Same way it is been done for batch ray tracing.
It would be great, to be able to explore in the viewer, the ray bundle been batch ray traced.
Best regards
Dimiter
@Xianglei
Excellent work, and amazing feature.
I’d like to double down on what @MichaelH said. We have the Pan attributes but it would really be awesome to also have the Zoom. I can already imagine the nice animations we could create *_*
This is a great new feature, well done. I’d love to see all the little gaps in ZOS-API being aggressively filled so that ZOS-API really does allow 100% of the things done by mouse and keyboard. Right now we’re at around 95% and those last few % are real killers if you’re on a time budget and you need one of those few missing items.
  • Mark
Ansys Staff
  • Ansys Staff
  • May 17, 2024
Hey Dimiter,
If you’re in sequential mode, look at the Raylist.txt in Zemax\Miscellaneous folder and then change the RayPattern setting to List.  By default, the Raylist.txt will trace rays to the normalized pupil coordinate for the specified field, but if you want direct ray tracing, you start the Raylist.txt with the EXPLICIT keyword and then define your XYLMN + wlum.
If you’re in non-sequential mode, you can define your initial rays in a Source File and then just make sure the # Layout Rays match the number of rays defined in your Source File.
dgeorgiev
  • May 22, 2024
Hi Michael,
Thank you for the great hint!
It solves exactly what i needed. It feels slightly like a life hack but I am happy with it.
Best regards Dimiter
  • June 19, 2024
I tried the code for sequential layout previously and it was working well. But recently, the software was updated to Ansys Zemax OpticStudio 2024 R1.03 and ran into the following error when calling ‘Layouts’:
AttributeError: 'SystemTools' object has no attribute 'Layouts'
Wondering if anyone has this issue as well?
Regards, Ai Ping
Brian
  • July 9, 2024
Hi
I’m continuing as to what Ai Ping observed.  I’m using the API with OpticStudio 2024 R1.02 and the Layout being returned from TheSystem.Tools.Layouts.OpenCrossSectionExport() is returning a NULL reference.
Is there anything that I'm missing to make this work?
Thanks.
B.
Brian
  • July 9, 2024
All Set. Resolved The Issue. GDI will complain about an illegal path for filename. What’s weird is that the call to IsValidFileName returns false when giving a legal filename with a path. If I just give a filename without a path then IsValidFileName returns true but then GDI exception occurs.
BTW, I still can’t create a OpenCrossSectionExport() for some reason.
FYI, I switched to using OpenShadedModelExport() and I’m now getting a Layout object.
However...I’m know getting an exception when I call RunAndWaitForCompletion().
The exception is : “A generic error occurred in GDI+”
Using the API library in C# with .NET frame 4.8.1 and OpticStudio 2024 R1.02
Thanks
B.
Alberto.Donazzan
I follow up to this quite old thread to ask you experts some advice. I am trying to convert a 3DLayout image (IImageExportData object) into a numpy array. This is some sample code:
Layout3D = TheSystem.Tools.Layouts.Open3DViewerExport()
…various layout configurations…
Layout3D.SaveImageAsFile = False
Layout3D.RunAndWaitForCompletion()
im = Layout3D.ImageExportData
imnp = np.empty([im.Height, im.Width, 3])
for i in range(im.Height):
    for j in range(im.Width):
        pixel = im.GetImagePixel(j,i)
        imnp[i,j,:] = [pixel.R, pixel.G, pixel.B]
plt.imshow(imnp)
My problem is that this code is way too slow: 41 seconds execution for a 2048x1080 pixels image.
I tried to work with im.Values, but my python kernel keeps crashing.
Is there a way to get values from a IImageExportData object in a more efficient way?
Thank you for your precious help.
Ansys Staff
  • Ansys Staff
  • May 21, 2025
Hi Alberto,
Unfortunately, I don’t think you can easily speed this up with built-in tools for Python.  The main bottle neck is that for your nested for loops, you have to call GetImagePixel() each time.  Each time you call the function, there is a Python-NET-Python exchange that occurs and although this exchange is quick, there is a slight overhead due to Python being written in C and the ZOS-API written in .NET.  So, although the overhead is very small, when you loop through a 2048x1080 pixel image, you’re calling the GetImagePixel() method over 2.2 million times, so even if the overhead is in the 10’s of microseconds, you’ll see a ~41 second execution.
The 2 options I recommend are either to save the output and use Pillow to parse it or to write a C# DLL that offloads the GetImagePixel loop natively to .NET.
To directly save the output, you can use Layout3D.SaveImageAsFile = True and Layout3D.OutputFileName = r"layout.png".  To read in the file, you can use PIL and numpy.  Some pseudo code would look like:
import matplotlib.pyplot as plt
import numpy as np
from PIL import Image
# create a saved filename (this should be a fullpath)
fn = r"layout.png"
# use ZOS-API to save the PNG
Layout3D.OutputFileName = fn
# open the image and convert to RGB
img = Image.open(fn)
img_rgb = img.convert("RGB")
# convert to numpy and extract channels
img_np = np.array(img_rgb)
# if you want the individual channels
r = img_np[:, :, 0]
g = img_np[:, :, 1]
b = img_np[:, :, 2]
# plot the image
plt.imshow(img_np)
plt.show()
The second option is to create a C# DLL that will offload the processing of the GetImagePixel() and return 3 double[,] arrays.  This is similar to speeding up the IBatchRayTrace in Python:
Batch Processing of Ray Trace Data using ZOS-API in MATLAB or Python – Knowledgebase
Alberto.Donazzan
Dear ​@MichaelH, thank you for your suggestions.
I think I will go with the “save to disk” approach, even though quick and dirty 😅
I’d love to see in the future some ready to use method such as
im = Layout3D.ImageExportData.ToArray()
Ansys Staff
  • Ansys Staff
  • May 22, 2025
Hey ​@Alberto.Donazzan, I doubt this will be added directly to the API, but I was able to do a quick test by modifying the concept of the BatchRayTrace DLL from the link above.  The C# code is pretty simple to offload the parsing from Python to C#:
using ZOSAPI.Tools.Layouts;
namespace Layouts
public class GetPixelValues
private IImageExportData DataSource;
public GetPixelValues(IImageExportData image_data)
this.DataSource = image_data;
public RGB Run()
var output = new RGB();
// get the size of the output image
int width = this.DataSource.Values.GetLength(0);
int height = this.DataSource.Values.GetLength(1);
// initialize the results to the correct dimensions
output.r = new int[width, height];
output.g = new int[width, height];
output.b = new int[width, height];
// loop through each pixel and store the value in an output class
int idx = 0;
for (int row = 0; row < width; row++)
for (int col = 0; col < height; col++)
output.r[row, col] = this.DataSource.Values[row, col].R;
output.g[row, col] = this.DataSource.Values[row, col].G;
output.b[row, col] = this.DataSource.Values[row, col].B;
idx++;
return output;
public class RGB
public int[,] r;
public int[,] g;
public int[,] b;
And then to use it in a Python script, you can use:
# include moduels
import clr
import numpy as np
import os
import time
# get the layout DLL data
import Layouts
# load sample data
TheSystem.LoadFile(os.path.join(os.path.sep, TheApplication.SamplesDir, r'Sequential\Objectives\Double Gauss 28 degree field.zmx'), False)
# open 3D Viewer and export with default values
tool = TheSystem.Tools.Layouts.Open3DViewerExport()
tool.SaveImageAsFile = False
tool.RunAndWaitForCompletion()
# get layout data
im = tool.ImageExportData
# pass Layout data to DLL
t0 = time.perf_counter()
layout_dll = Layouts.GetPixelValues(im)
output = layout_dll.Run()
# convert output to numpy arrays
r = np.asarray(output.r)
g = np.asarray(output.g)
b = np.asarray(output.b)
# stack numpy to RGB matrix
rgb = np.dstack((r, g, b))
# plot RGB image
plt.imshow(rgb)
print(f'total time : {(time.perf_counter() - t0):.2f} seconds')
plt.show()
For a 1920x1080 image, this C# DLL takes around 0.3 seconds to process and then matplotlib can plot the image instantly.
Alberto.Donazzan
@MichaelH thank you so much for this further piece of code. I will review and test it.
