Accessing lost energy in the Python API
  • Apr 21, 2021 8:53 PM UTC
  • 181 views
c​hris
How do I access 'Lost energy (thresholds)' and 'Lost energy (errors)' in the Python API? I didn't see anything in the syntax help.
Hi Chris,
Those are properties of your INSCRayTrace:
double  DeadRayErrors [get]
double  DeadRayThreshold [get]
You find this in the Syntax Help file under: ZOSAPI > Tools > RayTrace > INSCRayTrace. But there isn't much documentation about it.
Here is a code snippet showing you how to call those properties:
# Setup and run the ray trace
NSCRayTrace = TheSystem.Tools.OpenNSCRayTrace()
NSCRayTrace.ClearDetectors(0)
NSCRayTrace.SplitNSCRays = True
NSCRayTrace.ScatterNSCRays = True
NSCRayTrace.UsePolarization = True
NSCRayTrace.IgnoreErrors = True
NSCRayTrace.SaveRays = False
NSCRayTrace.RunAndWaitForCompletion()
print('Lost energy (errors): ', NSCRayTrace.DeadRayErrors)
print('Lost energy (thresholds): ', NSCRayTrace.DeadRayThreshold)
NSCRayTrace.Close()
print('Finished ray trace')
Let me know if this helps.
  • Apr 22, 2021 8:46 AM UTC
Hi Chris,
NSCRayTrace.Close()
c​hris
  • Apr 22, 2021 4:14 PM UTC
That helps, thanks. I was looking for 'lost' in the documentation - choosing one name or the other would be helpful.
Hi Chris,
I completely agree with you. Perhaps someone from Zemax can raise this issue to the developers?
Cheers,
Allie
  • Apr 27, 2021 10:59 PM UTC
Hi Chris and David,
Thanks for noting this! I agree that it would be useful to align the terminology here. I will submit a feature request to our developers :).
Allie
