Ask an Engineer: How do I import a CAD component in sequential design into OpticStudio?
  • August 3, 2022
  • 808 views
Event Details
Topic: Utilizing a custom CAD component within Sequential Mode in OpticStudio
Live demo and Q&A: August 24th, 8am - 9am PDT (See the attachments for a calendar invite)
Engineer:​@Gernot.Blobel - Senior Application Engineer, Ansys Zemax
Ask an Engineer is a once-monthly live event. The meeting is a small, informal gathering wherein our technical staff will take the time to educate and answer questions on the featured topic. We highly encourage new users - especially students - to join and learn a bit more about the software!
Take a look at the topic and resources below, then join us on August 24th to connect with our engineer.
Live event: August 24th, 8am PST (the calendar invite may be found in the attachment link at the bottom of this post)
Topic:
It is often the case that our optical systems utilize unique parts or objects designed in-house. For example, a vehicle’s windshield shape (an important component of a HUD system) may be proprietary information that we would need to include within our optical model to have a full understanding of the system performance. For this reason, the ability to import CAD objects into OpticStudio is very important.
OpticStudio offers various approaches for importing CAD components in sequential design. I'm excited to show you different solutions and answer questions about that in this month’s "Ask an Engineer" event. Please ask your questions about importing, fitting, and optimizing CAD parts in sequential design.
Resources/Tips:
There are several approaches one can take to complete this task. It may be useful to familiarize yourself with two of them. Check out the Knowledgebase articles below to get started:
Questions? Comments?
Reply to this thread! We will accept questions in English, Chinese, or Japanese. Following the event, the thread will be closed, so if you have something related to this topic that you’d like to discuss, add it now!
Please note: the Ask an Engineer live event will be limited to discussing this challenge and general questions related to the topic. For questions on troubleshooting personal OpticStudio files, please submit a ticket with Zemax Support. In that case, your license support status will be considered.
Click here to download
Ryosuke.Niitsu
テーマ: OpticStudioのシーケンシャルモードでカスタムCADパーツを使用する。
ライブ解説および Q&A 回答日時:8月24日 午前8時~午前9時(米国太平洋標準時)
エンジニア:@Gernot.Blobel - Ansys-Zemax シニアアプリケーションエンジニア
Ask an Engineerは、月に一度のライブイベントです。
このイベントは小規模で非公式なものとなっております。
弊社の技術者が特集しているトピックについて解説し、質問に答えるというものです。
新規のユーザー様や、特に学生の皆さんに、ぜひ参加していただき、
ソフトウェアについてもっと知っていただきたいと思います。
8月24日(水)に開催されるので、ぜひご参加ください。
ライブ解説および Q&A 回答日時:
8月24日午前8時~午前9時(米国太平洋標準時)  (ライブへの招待状は、この記事の下の添付ファイルのリンクにあります)
課題:
光学設計では自社で設計した独特の物や部品やと使用することがよくあります。
例えば、車両のフロントガラスの形状(HUDシステムの重要な構成要素)は、
システムの性能を理解するために光学モデル内に含める必要がある専有情報の可能性があります。
そのため、OpticStudioにCADオブジェクトの情報をインポートすることは非常に重要になります。
OpticStudioはシーケンシャル設計にCAD部品をインポートするために
様々なアプローチを提供します。
今月の「Ask an Engineer」では、様々なソリューションをご紹介し、
それに関する質問にお答えします。
シーケンシャルでの設計におけるCADパーツのインポート、フィッティング、最適化に関する
ご質問をお寄せください。
リソース/ヒント:
この作業を行うためのアプローチはいくつかあります。
そのうち2つのアプローチに慣れておくと便利です。
下記のナレッジベースの記事を参照ください。
質問/コメント
このスレッドに返信してください。
返信は、サポートされている言語 (英語、中国語、日本語) で投稿できます。
イベント終了後、このスレッドは閉鎖されます。
Ask an Engineer ライブイベントは、この課題への挑戦と一般的な質問に限定されます。
個人用 OpticStudio ファイルのトラブルシューティングに関する質問については、
Zemax サポートにチケットを提出してください。
その場合、お客様のライセンスサポート状況が考慮されます。
添付ファイル
ここをクリックしてダウンロード
Haosheng.Hu
  • August 4, 2022
活动详情
主题:在序列模式的 OpticStudio 中使用用户定义的 CAD 元件进行设计
在线演示和问答:8月24日,8 am - 9 am 北美太平洋标准时间(附件内包含日程邀请)
工程师:@Gernot.Blobel - Senior Application Engineer, Ansys Zemax
作为每月一次的工程师在线演示和问答活动,我们将组织一个小型的非正式会议,旨在通过我们的技术人员就某一技术主题进行讲授和问题解答。我们将高度鼓励新用户,尤其是在校学生加入并学习更多关于软件应用的相关内容。
敬请查看以下主题和资源,并在 8 月 24 日当天加入我们的会议与工程师一起进行讨论!
会议时间:8 月 24 日 8am 北美太平洋标准时间(您可以在本论坛发布底部找到日程的对应邀请信息)
通常情况下,我们在光学系统中通常将使用独特的元件物体或是内部设计。例如,车辆的前挡风玻璃(HUD 系统的重要组成部分)将作为我们需要在光学模型中包含的特有物体,以便全面了解 HUD 系统的性能。因此,在 OpticStudio 中导入 CAD 对象的能力是非常重要的。
OpticStudio 提供了在序列模式设计中导入 CAD 元件的各种方法。我们将很高兴在本月的 “提问工程师” 活动中向您展示不同的解决方案并回答有关问题。在此,我们邀请您参与序列模式设计中导入、装配、优化 CAD 零件的问题咨询活动。
资源与提示:
在我们的官方知识库中提供了几种方法可以用来完成这项任务,熟悉其中两种方法将极大程度帮助您完成设计。还请参考以下的技术支持知识库文章开启设计:
提问以及评论:
您可以通过回复这个帖子进行提问。我们将接受英语、汉语或日语的提问。在活动结束之后,我们将关闭该帖。如果您有与这个主题相关的问题想要讨论,或是想要添加任何评论,请在此进行添加。
请注意:提问工程师的现场活动将限于讨论当前主题及其相关问题。关于解决个人 OpticStudio 文件设计和故障问题,请结合您当前的 OpticStudio 授权服务支持状态,提交 Zemax 支持请求。
  • August 10, 2022
I have a question about stray light analysis with CAD in NSQ.
Here is the case, I import a CAD file into NSQ editor, for example, half-sphere, to do this stray light analysis. I would like to know how much light is scattered or back-reflected back to the source (e.g., light is reflected back to the laser source which we hate it) by the two surfaces (flat base and curved surface) of the object.
Is it possible?
I know that there is Path Analysis tool in Zemax, however, it is only for each object but not specific surface of each object.
Thank you.
Oliver
