Paraxial magnification
  • February 14, 2021
  • 2311 views
I ould be really thankful for clarification how to achieve a paraxial Magnification.
So I have system of two paraxial lenses with focuses 100 and 200. And I need to determince distance beween lenses and distances from lenses to the object and image. The magnification is M=-1.1x and total length of the system is 800mm.
So what I did. I definedthe obeject height 1mm in Fields and in merit function determined operand REAY with Py=1 and target=-1.1 to receive Magnification -1.1. But afer the optimization Paraxial Magnification less or higher than desired -1.1x.
So how is it possible to achieve the exact magnification M=-1.1x?
Thank you in advance!
  • 337 replies
  • February 18, 2021
Hi Anastasiia,
In your merit function, the REAY operand has Hx=0, Hy=0, Px=0, Py=0. This defines a ray starting at the (0,0) field position, which is on-axis, and traveling through the edge of the pupil. This is not what you want. You want to start the ray at the y=1 height so Hx=0, Hy=1, and send it through the center of the pupil, so Px=0, Py=0. (Note that Hy=1 because the normalized field is 1 for the ray height of 1mm.) Yout then target that ray to land at y = -1.1mm for a magnification of -1.1.
Note that you could also use the operand PMAG for paraxial magnification. (AMAG is angular magnification -- we want PMAG for a focal sysytem.)
It is worth noticing that is we weren't using paraxial lenses, the REAY would not necessarily result in a -1.1mm strike on the image plane because that is not a paraxial ray.
It's also worth noting that the optimizaton made the distance to the first lens nearly zero. This means the power contributed by that lens is negligible -- it could be eliminated from the design.
Kind regards,
