Hi all,
Is there any way to block specific rays from propagating in non sequnetial mode?
for example, in the attached file, I want to block only the first source and allow the second one to propgate.
Nadav
Simply set “# Analysis Rays” to zero for the source that you don’t want to use, which effectively blocks it.
You can use “Annular Stop” to block the rays.
