I need to simulate a gaussian beam in non sequential mode, which has 850 nm wavelength, 15 degree diveregence angle (half angle) and the beam raduis of 2.563 mm at 10 mm which has the cross section of the beam profile shape as attached below, but when putting this values using the Gaussian source it doesnt give me the same results.
By using the skewRaysCircular I cannot get the gaussain beam profile and it just shows me a ring, how can I get a gaussian beam profile in the output?
