How to convert CodeV Decenter type "Global Coordinates' into Zemax
  • October 15, 2024
  • 96 views
hahapypy
I have a surface “OBJ_EP’’ in Code V. Its thickness is 7.049 and the decenter of it is below
What I did in Zemax: create 3 coordinates breaks ahead of the surface as image below. The first one is coordinate return Orientation XYZ to the global reference surface “ILL_IMS” as CodeV. The second is YZ shift. The final one is tilts (I am aware of that the tilts sign is opposite b/w CodeV and Zemax)
However the convert result does not look right. Can anyone help? thanks
hahapypy
  • October 15, 2024
I missed my CodeV decenter description, please see below
