Optimal lighting layout for vertical farming
Hi, I am a student trying to improve light uniformity for a hydroponic system. Which layout would be optimal, square, rectangle etc. Also, how do I determine the distance between each LED. Are there are any optical structures (i.e  Fresnel Lens/Collimator) there are simplified so I can make to improve light uniformity?
Thanks, appreciate your help.
