.pcd - Cloud Point File Structure
OpticStudio's tool to export point clouds creates a lens.pcd file. The 11 first lines are information about the file structure, then followed by the points.
# .PCD v0.7 - Point Cloud Data file format
VERSION 0.7
FIELDS x y z
SIZE 4 4 4
TYPE F F F
COUNT 1 1 1
WIDTH 100
HEIGHT 100
VIEWPOINT 0 0 0 1 0 0 0
POINTS 10000
DATA ascii
Could someone fill in the blanks?
VERSION    ->    Tool Version Number
FIELDS       ->    Order of Coordinates
SIZE           ->    ?
TYPE          ->    Number Type? In this case Float?
COUNT       ->    ?
WIDTH        ->    Number of Data Points along the Width?
HEIGHT       ->    Number of Data Points along the Height?
VIEWPOINT ->    ?
POINTS       ->    Number of Data Points
DATA           ->    Data Encoding
Best answer by Mark.Nicholson
Hey Victor,
Full file format specs are at https://pointclouds.org/documentation/tutorials/pcd_file_format.html
Perfect!
Thank you very much!
