Macro Solves in parent objects for Compound Lens
I am trying to generate a compound lens with front and back surfaces made up of two Biconic Zernike surfaces.  One of the aspheric parameters on the front biconic surface is generated by a ZPL macro.  When building this model, the compound lens ignores the value provided by the ZPL solve, treating it as it were zero.  Is there any way to pass the surface generated by the macro solve to the compound lens without having it be ignored?
Be the first to reply!
