Major Release
OpticsViewer 20.2 Release Notes
  • July 27, 2021
  • 27 views
Allie
  • 346 replies
Released: May 19th, 2020
OpticsViewer 20.2 contains the following fixes and enhancements.
Performance & Stability
  • CAD Export Tool – Non-circular apertures are now better supported.
  • Gradient 12 Surface – Fixed error when the Material column was not defined.
  • License Manager – Allow setting the Default license in the Zemax License Manager without first opening OpticsViewer
  • Field Data Editor – The graphic visualization of field data points has been improved for systems with large fields of view defined by Angle.
Bug Fixes
  • SSAG Operand – Updated to now return the correct values with both the Mechanical Semi-Diameter and the Semi-Diameter
  • Export to Point Cloud – Now uses the correct Semi-Diameter when Include Normals is enabled
