How can I calculate the diffraction efficiency of HOE?
  • July 1, 2020
  • 123 views
I was trying to calculate the efficiency for user defined surface: us_hologram_kogelnik;
I followed the manual and it works fine when the construction is
However, when z2=-23, the efficiency reduce significantly and the plot was like:
I’ve already move the image surface to the focal plane. I don’t know if it is correct.
Please help me.
Hi
Really sorry about this but we are unable to see the images added to your post.
Would you mind sending the images as an attachment?
I'll report this issue to our portal master.
Sandrine
