About the method that converting Zernike Sag to Zernike phase
  • September 19, 2025
  • 30 views
Hello, All
I’m looking for how I can convert the values from Zernike Standard Sag to Zernike Standard Phase for TOLR Analysis
The Lens Data applying Zernike Standard Phase to Extended Polynomial surfaces in TOLR Analysis
when we are closed look for Lens Data, I set Extended polynomial and Standard with Zernike Standard Phase.
It is expedient to apply surface Irregularities which is for can not apply directly to Exteneded polynomial.
Of course I know that there is new function names Composite Surfaces, however The TEZI operands of composit surfaces  can not apply now. (Special Case)
So I set the surfaces to duplicate real phenomenas and to be avoid the situation that could not apply TEZI opperands to the surfaces(not Standard).
So, what I would like to ask you is how I can determine the scale factors from Zernike Standard Surfaces(will be change by TEZI Operands) to Zernike Standard Phases.
Picking up from Standard surface16 to 17 zernike 7
NO reflecting TEZI result applied on surface 16 without picking up by Zernike Standard Phase Surface
I am asking this because I am not sure how Opticstudio is working for this. If you know Please share withe me. I would realy appreciate.
Thank you and Best Regards.
Be the first to reply!
